460 start up - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2006, 12:05 PM
460 start up
I recently acquired a 460 Ford engine. It has been totally rebuilt and bored .030 over with aluminum heads. I don't have many spec facts on the cam, but was informed that it has been degreed, valves adjusted, etc. and is ready to be started. Do any of you experienced engine guys have a play by play start up procedure? ie.(prime oil pump, break-in rpms, break-in duration , how many total minutes at higher rpm..etc.) I am anxious to hear this thing....also, is it ok to break-in with open headers or no?
thanks,
James
Old 03-16-2006, 05:25 PM
LilSmoke's Avatar
First thing is to pull valve covers and verify lash or preload.then pour some assembly lube into the rockers if they are stock. Pull #1 plug and verify static timing and firing order. Then pull dist and make a hex drive for the oil pump and spin it with a drill and verify oil out the pushrods and pressure.Reinstall dist and check all plugs for gap. Open headers are ok. Go right to at least 1800 rpms and preferably to 2000 and time and check each pipe for heat. 20 to 30 min with no idle time. If it gets warm,shut down and restart when cool and continue. Make sure 30 wt oil and EOS equivalent in pan.Once broke in, Recheck head torque and retighten intake and pan and pull valve covers and check to make sure its still clean. Drop oil and filter and cut filter open and verify no metal. Put in normal oil and filter and then idle down and set mixture and check vacuum along with initial timing.Done
Old 03-16-2006, 10:48 PM
aka Duke of URL
Verify cam type flat tappet/roller-solid/hydraulic. A roller does not need break-in.
Old 03-17-2006, 06:57 AM
460 Engine
Thanks guys. It has hydraulic lifters and roller rockers. I will hopefully fire it up in a month or so....will keep posted.
thanks again
Old 03-17-2006, 08:47 AM
aka Duke of URL
Let me clarify this statement before I cause confusion. A roller cam does not require break-in. A flat tappet cam does require break-in.
350 sbc upgrade... Engine will not start FenderGitars Engine 10 10-08-2010 03:26 PM
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 29 06-18-2009 06:54 AM
caprice wont start? Brian Morency Engine 8 08-24-2004 11:37 PM
Starter Sizzle, No Start bjam2 Electrical 13 07-16-2004 04:32 AM
Won't Start after sitting?????Help! Weimer Engine 17 05-14-2004 12:36 AM
