Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Engine
  #31
Old 03-31-2008, 07:03 PM
Jared's Avatar
Jared Jared is offline
re: 460 stumbles at/wont pass 2800 rpm
I set the float setting lower so it is low to mid glass and now the bogging after accel is gone. I checked vac it idles at 13" I had to steal the vac advance line to check it though. Im thinking my plumbing of the pcv might be some of the problem. I just ran a hose from the back of the carb to a tee and to the booster and pcv off from it. could that cause a problem? any Idea what a 750 mech sec. speed demon runs for jets any way? I have a jet kit somewhere but should make sure I have what I need in it before im into the carb.......I have this habbit of needing the one jet size im missing.
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "460 stumbles at/wont pass 2800 rpm"
267 small block chevy chevellecamino Engine 33 11-15-2008 03:46 AM
Whats wrong with the performer rpm cam?. 7fastelc0 Engine 19 12-09-2006 05:49 PM
New RPM Dual Quad Air-Gap Intake bccsrc Engine 7 01-31-2006 04:29 PM
DIY Shiftlight/ RPM Switch/ RPM Window Switch Junorr Electrical 2 09-07-2004 07:18 PM
460 flywheel, 400 pressure plate? billybob_v10 Transmission - Rearend 2 07-02-2004 11:51 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
