460 swap, 68 torino - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2007, 09:00 AM
460 swap, 68 torino
Hi, I put a 460 in a 68 torino, and the valve covers that have to be used will hit the master cylinder. My question is: Can I move the master cylinder over?
Old 11-05-2007, 04:02 PM
Last journal entry: Brake? Steering?
Master cylinder .........
You've probably already figured this out by now but thought I'd throw in my two bits. I'm building a 55 Ford and have a 429 sitting in it. The 429 / 460 are basically the same in outward size. I was going to put in a Granada master cylinder with p.b booster but found that the booster hit the valve covers. I contacted a guy running a 428 with a 671 blower and asked what he had for brakes. He has disk / drum like I'm running and told me he runs a non-power master cylinder which removes the booster. Since I'm using the Granada steering column / pedal hangar, I looked online at NAPA and Schuck's auto parts sites and found that this car used a manual brake system with the disk / drum configuration. The other guy said his car stops "fine" without the power brake option. The answer to my problem of room restrictions was to use the manual brake master cylinder which cost me $20 bucks for a rebuilt unit and that included the core charge (Schucks). I modified my mount which I had to do anyway to get the pedal / column mount set up (wider hole spacing than the original equip.)
sorry for being so long winded. But what I'm saying is this. Buy a manual brake master cylinder and eliminate the power booster which will interfere with the valve covers on your 460.
Hope this helps!
68 Firebird Disc Brake Swap blacktoothgrin Suspension - Brakes - Steering 12 02-16-2007 07:40 AM
LS1/2 Swap into a 68 Firebird blacktoothgrin Engine 6 02-11-2007 10:41 AM
1996 460 efi swap, no alternator function. Jared Electrical 7 11-26-2006 08:56 PM
Ford 460 swap 67 Burnouts Engine 0 05-28-2004 02:25 AM
Engine swap for 68 austin healey 68HEALEY General Rodding Tech 2 09-04-2003 03:45 AM
