Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 460 tad blue smoke?
Old 11-07-2012, 06:50 PM
lil-vulky lil-vulky is offline
Originally Posted by birkey View Post
Use a piston stop or dial indicator to accurately locate true tdc. Visually it is almost impossible to find. You might be a tooth off.
being a tooth off will that stop my timing being set right? thats what i was thinking before but then i thoughtwith a timing light i could still set it right because i can turn the dizzy to set it back to where its ment to be? or does that not work
