Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 460 tad blue smoke?
Old 11-07-2012, 06:54 PM
birkey birkey is offline
Not gonna run right a tooth off no matter what. First you need to find true tdc then go from there. Set the distributor halfway between travel advance and retard. You can set it after it is running. Bad ignition setup will cause backfire.
The Following User Says Thank You to birkey For This Useful Post:
lil-vulky (11-07-2012)
