Originally Posted by birkey
Not gonna run right a tooth off no matter what. First you need to find true tdc then go from there. Set the distributor halfway between travel advance and retard. You can set it after it is running. Bad ignition setup will cause backfire.
this is a video of it running
Seen im not sure what these engines are ment to run like do i need to reset my distributor you think? am planning on taking it to mechanics to properly tune the carby and rekit my back brakes etc so might get him to double check my dizzy settings for me, just trying to do as much as i can because im dead broke this is the 2nd time i brought a car where the seller completely lied =[
