Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 460 tad blue smoke?
Old 11-08-2012, 05:29 PM
lil-vulky lil-vulky is offline
Originally Posted by birkey View Post
Oh that would be nice. I got mine from summit cheap. Does your balancer have a mark for tdc?
yup thats what i wound the crank pulley around to, so it was roughly showing tdc on the marking then i put my distributor in started straight away then i used a timing light to try get it at 8degrees btdc but not sure if its right or not was so hard to see the markings in bright as sunny day the light wasn't bright enuff so might be off by a few degrees. will get better timing light and double check
