460 timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-07-2012, 07:57 PM
460 timing
Hi can anyone tell me what the timing is set at on a 1971 mark111 lincoln 460 im new at this and could use some help thankyou Miggs
Old 08-07-2012, 08:47 PM
hp246's Avatar
10 degrees BTDC
Old 08-08-2012, 05:19 AM
miggs Thankyou hp246 im in ontario canada
Old 08-08-2012, 06:34 AM
Wiki Edits: 27
vacuum setting
On a lot of 460's you can pull the vacuum hose off the distributor and use an 1/8 allen wrench to adjust the vacuum spring tension to fine tune the advance curve.
Old 08-08-2012, 07:01 AM
Irelands child's Avatar
Then of course is that big bug-a-boo, the 9* retarded timing gear/camshaft assembly and straight from Ford trying to make an "economy" engine out of that gas hog (of which I owned four, all of which received new timing sets)
Dave W
Irelands child
Timing 460 ford taclet Engine 2 08-03-2005 10:24 AM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 08:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
Setting timing on Ford 460 cboy Engine 7 06-30-2004 11:30 AM
460 timing billybob_v10 Engine 2 09-05-2003 02:26 PM
