460 to toploader conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2008, 07:19 AM
ajbcc2's Avatar
Last journal entry: frankenstude too
I wanted a 4 spd behind my 1969 460 thats going in my 31 stude 5 window coupe.i pulled the c6 off, bought a 184 tooth flywheel(it had a bolt pattern spacing of 12 3/8 for the pressure plate so its for a 360) got the clutch assembly, then got a bell housing off of an 85 ford truck that had a 460 complete with hydraulic clutch release setup..the small block toploader has the longer(although weaker..careful!) input shaft and a 390 pilot shaft bushing and a 85 truck starter...and it all fits..i turned the motor over with the starter and no bad noises...cool
Name:	460 4spd pics 001.jpg
ID:	32852   Click image for larger version
Name:	460 4spd pics 002.jpg
ID:	32853   Click image for larger version
Name:	460 4spd pics 003.jpg
Old 09-25-2008, 08:23 PM
life is a temporary assignment
drum to disc conversion kits dmented Suspension - Brakes - Steering 4 06-06-2007 10:06 PM
Ford 460 vs 351W GranTorinoElite Engine 12 05-30-2007 10:31 AM
Ranger 460 Conversion fordboy_460 Hotrodding Basics 1 04-26-2006 10:21 PM
460 flywheel, 400 pressure plate? billybob_v10 Transmission - Rearend 2 07-02-2004 12:51 PM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
