460 trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2008, 12:25 PM
460 trans
Hi. Im hotrodding a 95 Ford pickup with a built 460. I was wondering if the original 4 speed od will bolt on or not? If not what other transmitions could I use other than the c6? Please help!
Old 02-06-2008, 05:46 AM
aka Duke of URL
No, the AOD has a SBF pattern.
For big-block or heavy-duty applications, you may wish to convert to the E4OD transmission. You will need a C-6 type flex-plate for your engine application and a transmission with the correct case style (small-block, big-block, or diesel). The drive shaft will probably require shortening and cross member and shift linkage modifications will be necessary, as described for the AOD. As with the AOD-E/4R70W, either a Ford EEC system or the Baumannator TCS™ Electronic Transmission Control System will be required to operate the transmission
-BAUMANN PERFORMANCE GUIDE-
Old 02-06-2008, 06:17 AM
woodz428's Avatar
Troll Hunter
I may be wrong Gary, but I think he was asking about the 3+OD that the top loader evolved into. You can make it fit, if you are talking about the top loader replacement, however it would probably only last a short time under the torque load. If it's the AOD, read Gary's post
I see he mentioned the C6, so it probably is the AOD..never mind.
Old 02-06-2008, 07:36 PM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
The E4OD was a morph update of the C6, they reused a substantial amount of components and designs, as well as manufacturing equipment.
Old 02-09-2008, 10:57 AM
Thanks,but I did mean the standard trans,sorry.
Old 02-09-2008, 11:01 AM
Thanks! you were right I had meant the3+od. I really appreciate the Information.
Later!
Old 02-09-2008, 11:05 AM
Thanks for the information,now I have a few choices.
Later.
4t60 Trans Question david hill Transmission - Rearend 1 04-10-2007 08:58 PM
Is a TCI street fighter 350t trans any good?? tiresmoke55 Transmission - Rearend 1 03-28-2007 12:04 AM
Allison Trans deseldr Transmission - Rearend 5 10-19-2003 07:45 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 01:23 PM
Fine metal in trans bigjoedo Transmission - Rearend 21 07-27-2003 11:50 PM
