460 vs 351m - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2008, 09:54 PM
"70" Cougar's Avatar
Meat-Head Extroidenaire
460 vs 351m
I own a 351m basically stock with edelbroke alum. intake and 600 carb. I'm goin to see about a parts truck tomorrow a 77 f150 2x4 auto. with a 460. My question is this which would have more power and wich would be smarter to use? a used (unknown) stock 460 or my current 351m. i know the 460 is a way better base to work off. but this 351m (other then this timeing chain thing) has been reliable for past year or 2.
thanks
billC
Old 02-15-2008, 10:01 PM
DoubleVision's Avatar
This is a no brainer. The 460 is 109 cubic inches bigger than a 351. The 351M isnt that popular, but scoring a 460 sure is.
Old 02-15-2008, 10:15 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
It might be worth tearing that 460 down and inspecting / refreshing it ... rings, brgs, and a valve grind. They have a pretty decent reputation, I think, for being strong and reliable.
Old 02-16-2008, 07:29 AM
onebadmerc's Avatar
I need a bucket of arc sparks
Here is a little song dedicated to the Ford 351M.......Anchors away my friend...Anchors away............No seriously go with the 460 even if it needs rebuilt.
Old 02-16-2008, 07:34 AM
woodz428's Avatar
Troll Hunter
There are more readily available pieces for the 460 and it bolts right up to the 351M bellhousing. Seems like a pretty easy decision as long as the 460 sounds and runs good.
Old 02-16-2008, 09:46 AM
Ok sounds good folks im off this morn. to have a look. Seemed to me from reading posts in here i was thinking that they were same bell housings but wasn't 100%. haha that almost makes my mind up for me haha
well then what is there interchange able between the two motors .ie carb plugs wires ... cause just did a full tune on the (boat anchor)
thanks
billC
Old 02-16-2008, 10:26 AM
66GMC's Avatar
It seems to me that some of those 460's used a spread-bore carb, but even if that is the case ... I guess you could use an adapter. 600 CFM is pretty small for a big engine like that ... especially if you're planning to rev it.
The entire distributor is interchangable. Plug wires should be OK, too.
Plugs? I think both of them used ASF42 or ASF52 ... the decal on the valve cover will tell you.
And that case of spin-on oil filters that you have will definitely work, too.
PS.
I politely refrained from calling down the 351M.
(I actually typed, then deleted the words : "Tie a big chain around it and market it as a boat achor.")
Old 02-16-2008, 07:33 PM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
Hey guys, the M ain't that bad. Not a lot of speed parts for it, but for a grocery getter or a parts chaser it can be tuned to a decent motor. My dad had one in a 73 or 74 Ford and I had a lot of fun with it.
Old 02-16-2008, 08:06 PM
powerrodsmike's Avatar
Wiki Edits: 161
thanks
billC
Ok the 460 wins hands down in the power department..
Now which one would be smarter to use?
Use for what?
Stump pulling ?
Hauling a trailer?
Driving back and forth to work with a carpenters toolbox?
Winning the mobil challenge gas mileage competition?
Driving kids to school?
Picking up chicks ?
What is the end use for this truck ,(bronco? I can't remember what you have)?
One of those 2 motors are better that the other in some areas, and fail in others.
Later, mikey
BE different....ACT normal.
Old 02-17-2008, 02:34 AM
Well its a 79 F250 4X4 4spd 60 rear 44 front 3.55's 5 inches of suspension lift. 36 inch inter-co's 10.5 wide. Ex logging first aid pickup (converted camper) But sad to say the truck i looked at today is poop rotten as the day is long. So no go im still on the look out for a good donor body/maybe a good mill. thanks again folks
billC
Old 02-17-2008, 08:50 AM
Wiki Edits: 161
Well it won't make a good street car no matter what, so go with the 460. If it had some 4:56 gears or even a set of 4:10's ,the 351 would be ok, but you need inches to pull those 3:55's
Mikey
Old 02-17-2008, 04:17 PM
Wiki Edits: 27
460 check
Check the timing chain. look at the distributor rotor and turn the engine back and forth with a wrench on the front crank bolt. see how much slop you have before the rotor moves the stock timing chains used to stretch alot by 30 k miles A new double roller is best. Set it dead on ... the factory retarded the cam for smog.and lost about 30 horses. if you use a stock chain get a 68 t bird crank gear I think it was a c8sb part number prefix
All Aluminum 460 Block thunderbird87 Engine 14 06-01-2007 07:28 PM
Ford 460 vs 351W GranTorinoElite Engine 12 05-30-2007 09:31 AM
Issue with Ford 460 clutch onebadmerc Transmission - Rearend 1 02-22-2007 06:15 PM
460 flywheel, 400 pressure plate? billybob_v10 Transmission - Rearend 2 07-02-2004 11:51 AM
carbed 460 or EFI 302 CustomFord Engine 2 04-16-2003 04:23 AM
