What he said.
The vacuum is influenced far more by cam and ignition timing, air/fuel ratio, engine tune as well as how good the engine is sealed, combustion-wise. |
Ok so i played with the timing and got it to pull 17.5". I have a stock aluminum intake and a set of 461 heads that I'd like to put on. Will either cause me to lose and vacuum over my stock cast iron intake and 336x heads??
As long as both pair of heads are the same, condition-wise, and the intake gaskets seal correctly, and the timing is put back the same, it should be identical for all intents and purposes.
The ignition timing, cam timing then I'm thinking intake design and carb size are also players in how much vacuum an engine will make. The intake port volume will affect the vacuum too, but to a lesser degree unless the port volume is much larger than before. Even exhaust tuning can affect vacuum, although I doubt you'd see it at an idle. |
Thanks. that makes sense. So will the 461's give me much of a performance increase over the 336x's? They will definitely be raising my compression ratio but mainly I figured they breathe better than the 336x's so I figured I'd see some more power.
The only difference with the intake is that the aluminum one has a hole that connects the passenger and driver side where the cast iron one doesn't. I was thinking that this might affect my vacuum but then realized that it shouldn't since the two sides are connected by the carb spacer anyway. |
If you thing the hole in the Q-jet intake is bad (which it sort of IS), the OEM 2-barrel aluminum intake for the '80 229 V6 is a single plane (as well as other years of the 229 and the 200 V6, I'd bet). Has nothing to do w/the intended usage or performance- it simply was cheaper to manufacture that way.
Yea I thought about plugging the hole but don't want to have to worry about the putty coming loose and making it's way into my engine. It's not worth it. Why should I plug it? Will it reduce my vacuum?
| F150 issues | ALL FORD | Transmission - Rearend | 27 | 06-30-2009 04:28 PM |
| timing question | Radchop | Engine | 7 | 11-19-2008 09:16 PM |
| Why spend money on heads? | F-1Rodder | Engine | 8 | 03-07-2008 12:09 AM |
| 68 charger lights | T-bucket23 | Electrical | 5 | 08-14-2006 05:07 PM |
