461 X Cylinder Heads - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
Old 05-25-2003, 07:53 AM
NAIRB's Avatar
Post 461 X Cylinder Heads
I have been doing a little research in the knowledge base, and looking a little at Mortec on their casting numbers for small chevy heads. I have a set of 461 heads originally on a 62 327. Mortec shows the 461X head being manufactured from 60-63 and the smaller port version 461 being made from I think 64-66. Now, do the 461 X heads all just have an X on them somewhere or is there some mis-information on Mortec concerning these castings? I think I have garden variety heads with a casting date of 1961, I don't believe these to be the sought after X heads. Any authorities on these out there? Bob?
Quick reply to this message
Old 05-25-2003, 09:37 AM
BOBCRMAN@aol.com's Avatar
Post
the X heads will have 461X cast into them, also you will find that the Mortec listing has several errors in it.
Old 05-25-2003, 09:52 AM
Post
Hello Nairb.
I got the 461 xs my self. This is what i have learned about them.
461 : Intake port vol 160 cc, 62 cc chamber.
461x: Intake port vol 172 cc, 62 cc chamber.1.94 Intake/ 1.50 exhaust
The casting number that you see when the valve cover is removed has no "X". If you flip the head over and look at the block mating surface there is an "X" cast on the water passage that connects to the intake manifold water passage. It's on one end only, near the #1 or #7 cylinder. The X is cast in not stamped. All the 461X heads were cast in 61-63. 64 and later will be plain 461.
Old 05-25-2003, 05:28 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
[quote]Originally posted by Swedishrodder:
<strong>Hello Nairb.
The casting number that you see when the valve cover is removed has no "X". If you flip the head over and look at the block mating surface there is an "X" cast on the water passage that connects to the intake manifold water passage. It's on one end only, near the #1 or #7 cylinder. The X is cast in not stamped. All the 461X heads were cast in 61-63. 64 and later will be plain 461.</strong><hr></blockquote>
Right on, that's where mine are. A buddy/racer of mine showed me that after I told him I found a set and bought them.
Old 05-25-2003, 05:57 PM
PrimeMover's Avatar
Sittin' on top of the world...
Post
NAIRB, the 461X heads will all have an "x" suffix. They're getting real hard, if not impossible, to find. World Products Tourquer II heads are real similar in runner volume to that of the early X head. They're 171cc runners with stainless 2.02's - 1.60's and 64cc combustion chambers. (I cc'd one, they're closer to 62) assembled out-of-the-box for around $690 a pair.
Old 05-25-2003, 06:40 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
Do they all have the "X" suffix? Mine have the "X" in the cooling port like stated.
Old 05-25-2003, 06:57 PM
NAIRB's Avatar
Post
These particular heads are the "X" heads, as there is an X underneath the heads on the water port. Mortec is correct here, and you can physically see the difference in the intake runner size. I pulled the heads off of the 327 this evening, but rust has taken it's toll on the block, sniff sniff-makes you want to cry, but I guess maybe a .060 overbore or even a sleeve will fix it back up. So, what are a good set of 461 X heads worth these days? Should I work em over or leave them be for Super Stock racers?
Old 05-25-2003, 07:05 PM
PrimeMover's Avatar
Post
A good unmolested matched set of bare 461X castings would be worth probably $250, around this neck of the woods. To a person who just HASTA have'em, they could be worth a lot more.. They're getting to be quite the prize at most swap events.
Old 05-25-2003, 07:50 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Post
I think if it was me, I would just give them a cleaning and a fresh valve job. I am sure you've got some valves laying around if those are toast. To someone putting a numbers engine together, they would be worth a pretty penny. To a racer I think the $250-350 range depending on condition and the amount of work that has been done.
I would suggest trying ebay. If you put all the numbers and take some really good pictures they should do well. Just set the minumum bid where you will not be disappointed
Chris
Closed Thread
