Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 468 bbc build suggestions on parts
Old 05-07-2013, 04:36 PM
Big Don1 Big Don1 is offline
I am building a 468 bbc and would appreciate all the help I can get on making at least 550 hp. It's a 2 bolt main 1973 mark IV, high performance pass stamped on block.9.8 deck stock crank and rods.It will be going into a 69 chevelle convertible. 700r4 built for 600 hp, 2500-2700 stall with a lock up switch,12 bolt pos 3:42 gears, 3" exhaust car weighs 4,200 lbs.I want to go full hyd roller with 10.1 compression would like all the input on pistons, heads, cam and carb. I drive this car every chance I get and keeping it reliable as a daily driver is a big plus. Thanks
