468 BBC F2 procharger build need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2013, 02:09 AM
Im putting together a 468 BBC with a F2 Procharger on its way. I don't really know a ton about the procharger systems and I would love the help of experienced people so any help is a plus thanks. I have a set of Oval Port Ported and polished heads that are going on the motor as well. What type of Crank, Rods and lifters are reccomended and what compression should I run? I was thinking 8:5:1 on the compression and also a solid roller set up as well. Im looking to get over 1000hp which I know can be done from reading forums online.
Old 02-08-2013, 08:54 AM
vinniekq2's Avatar
1000 hp? oval heads that flow how many CFM? what other parts are you using? ie;best crank and rods? may as well go 496?
if starting from scratch then 555 is even better
Old 02-08-2013, 08:26 PM
what size of intercooler would you reccomend? And I suppose the water intercooler with the ice box is the best for that too?
guesstimate HP/TQ on my bbc 468 roller build??? nfreas313 Hotrodding Basics 2 04-19-2012 08:59 PM
468 Bbc quicksilver67 Hotrodding Basics 1 10-12-2011 07:41 PM
Sould I build 496 or 468 BBC?? Help. MuscleBlock81 Engine 11 09-09-2009 02:14 AM
efi on 468 bbc roadkill468 Engine 0 08-21-2009 08:32 AM
468 bbc hp and tq?? 468ci1956 Engine 3 11-09-2006 02:00 PM
