468 engine build - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2009, 09:34 PM
468 engine build
i have a 454 big block chevy generation IV want to get 450 horse in a 71 chevelle. it has 781 heads, plan to do some port and polishing, was wondering if i needed bigger valves. need to know what size carburetor, what type of lifters solid or hyd? and type of intake, what kind of cam was wanting to run a 9:1 compression ratio and i will bore it .060 over to make it a 468, im 18 years old and new to the game any help will be appreciated
Old 10-14-2009, 09:54 PM
Guy Hiltz's Avatar
Here is a cam & lifter kit that would be a good choice;
http://www.jegs.com/i/Lunati/638/60203LK/10002/-1#
A dual plane intake such as the Weiand Stealth with a Mighty Demon 800 annular booster carb,here;
http://www.jegs.com/i/Barry-Grant/13...020GC/10002/-1
Dont bore it any more than is needed,its always a good idea to leave room for future rebuilds.
Guy
Old 10-14-2009, 10:04 PM
BOBCRMAN@aol.com's Avatar
781 heads respond tremendously to 2.19 intake and 1.88 exhaust valves. blend all edges in the bowls and smooth the short side radius. Smooth the upper 1/2 of the exhaust ports.
Cadillac engine build bluesman423 Engine 6 09-05-2008 06:18 PM
engine build - 451 stroker Highway Engine 8 07-17-2008 11:39 AM
Build me an engine! (on paper) :p mgray10 Engine 5 02-29-2004 05:02 PM
first engine build 71chevellepa Engine 1 09-13-2003 05:30 PM
Engine build for hire,decision 78 monte Hotrodders' Lounge 9 05-10-2003 10:44 PM
