46re disassemble problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2012, 09:45 PM
im rebuilding my dads 46re/rh out of his 93 dakota. All the clutchs and steels are gone and the park band is gone nothing left at all just steel. I have been looking all over the net for any info on rebuilding and im finding nothing. I was wanting to know on the tail shaft part of the trans after the first set of clutchs how do you get the 2nd set out. I can not get the middle gear out of the 2nd clutch pack which is making it hard to remove the lock clip on the clutch pack any info.
Old 06-23-2012, 03:50 AM
rick 427's Avatar
Last journal entry: The Cheetah
I'm not sure exactly where you're at in the disassembly,so i'll wing it....1] .extension housing is on the bench 2] round shaped retaining ring is removed 3]clutches and steels are removed 4] 2 more retaining rings,flat and wavy, are removed 5] oval exterior cover with 2 torx bolts on extension housing is removed 6] extension housing is placed on bench with the rear seal end facing up 7]retaining ring ends, behind the now removed oval cover, are spread open as far as possible,allowing the gear train to drop out of the extension housing...hitting the tailshaft with a rubber mallet helps 8] at this point, a HYDRALIC PRESS is needed to get the small snap ring in the front of the gear train,inside the external splined drum, off...THE SPRING PRESSURE BEHIND THE SPLINED DRUM THAT THIS SNAP RING RETAINS is along the lines of a front coil spring of a car,it could hurt you if not done right 9] it's all down hill from there.....
Old 06-23-2012, 11:48 PM
well thats alot of info and i got the splined drum off without a press i didnt see any spring at all. I think in some ways its easyer thin the 700r4 i rebuilt and in others its not but it will get done.
I also have to say these clutchs are so burnt i had to pry them off funny this truck would fishtail when you hammer it befor what will it do after its done and broke in.
Old 06-27-2012, 09:40 PM
I have the transmission apart but the rebuild kit is for a 46re/rh or 47re/rh which in the book that with the rebuild kit says the 46/47 re/rh trans have a different number of steels and clutchs in the OD. I dont realy know what to do i have all the clutchs in but an extra steel i dont know where it came from i dont want to take the spring loaded clutch pack out to check and i dont know where it would go.
Old 06-29-2012, 01:55 PM
i dont know anything about this trans but 2 of the 4 clutch setup have play. I have rebuilt a 700r4 that had no play on any clutch pack but a guy at a trans shop told me their should be play on some of the clutch pack.
Help me plz.
bad 46RE blackbird6872 Transmission - Rearend 1 03-29-2010 03:27 AM
46RE wont shift out of second. cutterbond Transmission - Rearend 5 01-17-2010 12:41 AM
How to disassemble air ratchet? mikeweb Garage - Tools 20 03-21-2009 10:52 AM
Disassemble used truck bed to paint? ChevyJim Body - Exterior 8 09-10-2006 08:44 AM
9 inch Ford disassemble procedure 38 ford 4 door Transmission - Rearend 2 04-03-2003 10:31 PM
