47 Chevy Business Coupe Front End questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2012, 09:25 AM
jbranontn's Avatar
I'm new to Street Rodding and traded for a 47 Chevy...It has the original front end and I need some help on it. I'm on a very tight budget and want to know what can be done to the stock front end to get rid of the floating bounce I get when I hit bumps. Is there anyway to add shocks to the front end? I was told it had a hydraulic system..can it be rebuilt or are there parts out there to replace any of this....I know I could change out the front end and probably will in the future, but wanted to do something now less expensive so I can enjoy the car now....Any help?
Old 10-18-2012, 05:04 PM
Last wiki edit: Removing stuck fasteners
47 front \end
I getting old, don't remember what you have, but I had a 40 chevy with what I heard was a knee actin shock. It had plugs in the main part to add hyd. fluild to improve the ride. I never messed with them tho, I welded a mustany 2 front end under it. changed to chevy rotors and made caliper brackets, had to get new beariing to fit spindles and rotors and seals. GL
Old 10-18-2012, 05:40 PM
Wiki Edits: 27
knee action
We have a 36 pontiac in the shop that has knee action, plus a spare. it has a curved tube axle then the big knee at the end that turns everything, the wheel and brakes at at the end of 2 links. so there is less unsprung weight, for a better ride when working correctly , but usually needs the spring-shock rebuilt every 30 K miles when they were driven on rough roads.
Old 10-25-2012, 07:46 PM
PRO 48 fleetline's Avatar
Last journal entry: Csr Electric Water pump
Theres really no cure or easy fix for that front end ecs. when you start adding power to it.
Heres what i ran in my 48 fleetline..AMC pacer front clip!
any ?'s just hollar!
1935 chevy business coupe headlights? akm Hotrodders' Lounge 5 06-13-2015 02:49 PM
1937 chevy coupe vs business coupe a70dart General Rodding Tech 14 06-04-2013 02:31 PM
1950 Chevy deluxe business coupe floor shifter A/G WILLYS Transmission - Rearend 4 12-31-2012 08:33 PM
1950 Chevy business coupe floor shifter CobraCop Transmission - Rearend 1 07-31-2012 05:30 PM
58 Chevy Delray business coupe Quick 58 Introduce Yourself 1 10-19-2007 12:15 PM
