47 chevy rear end swapping blues - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2012, 09:05 PM
Ok its been a while since Ive posted! But I gotta vent a little! I'm in the beginning stages of the SBC stove bolt swap. Ive ordered the front engine mounts and the universal transmission cross-member from CE . Only to find out the price of the rear end swap kit.... Has anyone ever bought one from gearheadworld on Ebay? his price is still over 500.00 but at least he offers free shipping!
Old 03-16-2012, 09:19 PM
Prof. T. Soggmeyer's Avatar
Plan B
I simply used a 1975 12 bolt rear end that I found in the local boneyard. Went through it of course, but it was very reasonable $$ wise. The width looks good under my 49.
Old 03-16-2012, 09:25 PM
did you use the original leaf springs? What about shock mounts?
Old 03-16-2012, 10:19 PM
Plan B
I could have used the original leaf springs, but I put new ones on all 4 corners that are 3" lower and the upper shock mounts are just fabbed in and the shocks use the lower mounts already on the 12 bolt. I paid 75.00 for the rear end when pick n pull was having a sale.
Brad...aka..Soggy
Old 03-16-2012, 10:31 PM
Are we talking pickup or car?
Old 03-17-2012, 06:23 AM
fleetmaster.....car!
Old 03-17-2012, 07:16 PM
Posie's makes a replacement spring that bolts up to the stock hangers, and drops the rear of the car about 3" with no blocks. Last I checked it was about $300 with new shackles and bushings. Nice ride too.
For shocks, 3/8" plate about 12" long with two holes drilled to fit the stock shock mounting holes on the frame, and one hole on the other end for the new shock.You might want to put a slight bend in the center so the new shock bolt clears the frame, depending on what mount your shock has at the top.
Old 03-17-2012, 07:40 PM
That sounds great on the price! but thats just on of the reasons Im unclear on the whole thing. I have dubonnet or knee action shocks. I found a chassis Engineering kit on Ebay for 574.00 with free shipping. It comes with new leafs, all the mounting hardware, and gas shocks. I guess thats the way Im gonna have to go. Now I have to figure out if a K member will be necessary.
Old 03-17-2012, 07:52 PM
Dubonet refers to a front suspension design used in the 30s by GM. Your car does not have it. Your shocks are a Delco piston type shock, and if they are good are perfectly fine. They can be rebuilt, but it's around $200 each to rebuild one. You front suspension if it's stock is called a SLA suspension, for SHORT, LONG, ARM, they type used on most rear drive cars since about 1940.
Old 03-17-2012, 08:22 PM
Thank you for the Info. But they are worn out and does not seem feasible to rebuild them.
Old 03-17-2012, 09:17 PM
I have patterns for the shock brackets for tube shocks. I can email them to you.
Old 03-17-2012, 09:25 PM
That would be super cool!! Thank you so much, here is my email hogbreath73@yahoo.com
Jaguar XJ6 -- swapping out rear end tylerwerrin Transmission - Rearend 10 11-23-2011 04:31 PM
Swapping Rear Ends sbchevyfan Transmission - Rearend 7 04-28-2011 06:51 PM
Rear end blues 55alive Transmission - Rearend 0 06-21-2006 06:56 PM
HELP!!!! swapping 2.41 to 3.42 rear Stevo Transmission - Rearend 5 11-08-2004 04:48 PM
Rear End Swapping 71gtx Engine 1 11-04-2003 08:11 PM
