47 Chevy steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2008, 05:59 AM
STEVE1103's Avatar
47 Chevy steering
Have a 47 Chevy with a 3.1 Camaro engine, need to find a power steering grear box that will bolt on the frame, with or without an adapter, and a pitman arm, (engine has the pump, don't want to have to figure a way to run the belt without the pump). Will use the Camaro column, no one makes a kit for this car!
Old 06-21-2008, 07:39 AM
1947 Chevy Coupe
On the '47 Coupe I'm doing, I decided to put a '92 4.3 V6 from an S-10 Blazer in it with the S-10 rear end and steering column. In looking at the front end, I figured the only way to go was to put a Mustang II IFS under it, which I'll start in a week or so.
It looks to me like a regular gear box would be more trouble than it was worth, and the $1665.00 I paid for the IFS was money well spent. This includes factors like the difficulty and expense of having to rebuild the existing front end.
Old 06-21-2008, 07:37 PM
STEVE1103's Avatar
Front end
I agree with you about the front end, mine has been completly rebuilt, I was told a cradled power rack & pinion might work, will look into that, don't have the money for a Mustang 11, Thanks for the info.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Chevy steering wheel donor for 39 chevy? Chevy39 Interior 12 07-24-2009 09:00 AM
Engine build ideas Rug Engine 23 12-25-2006 01:39 PM
'31 Chevy steering PA-Farmer Suspension - Brakes - Steering 2 08-15-2006 03:01 PM
Chevy Caprice steering column work - Rack Kit ViperMonster800 Suspension - Brakes - Steering 8 06-04-2006 04:43 PM
