47 dodge coupe build advice needed - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2006, 01:02 PM
OK in a nut shell. got a '47 dodge coupe. from what I have read the front suspension is pretty good as long as you relocate the shock mounts. can it handle the weight? the frame looks very beefy and mines good and solid. I'm looking for info on putting in a 383/727 combo. It looks like i'll be cuttin the firewall. I would also like to hear what you guy's have done for steering upgrades.
Old 06-19-2006, 02:16 PM
Crazy Mopar Guy's Avatar
My '40 is clipped, so I am of no help, but I have seen guys who have done the same combo as you plan with a relatively stock front end.
I ran a 440 in mine for years and years before redoing it, the passenger side of the firewall interfered with the rear of the passenger side head. I just modded the one side of the firewall. When I redid the car I moved the engine even farther back, and now I just made a completely different firewall from scratch.
I think you should have a little more engine compartment room with a 47 than my 40 has...?
Old pics...
Old 06-19-2006, 02:54 PM
looks good. I have a volare clip also that I may use but would like to keep the stock, coil spring ifs if possible.
Old 06-21-2006, 04:25 PM
no more feedback. I know there are a few people here dodges. Please advice.
Old 06-21-2006, 05:36 PM
BOBCRMAN@aol.com's Avatar
Use the stock Dodge basics. Change shock mounts, install a disc brake setup. Change steering to Cavalier rack and pinion. I also have dropped spindles. Most of this stuff is available from Fatman Fabrications.
My 48 B/Coupe has a Chebby in it, 400 turbo trans, 8 3/4" rear.
47 Ford 5 window coupe "hard" headliner DanTwoLakes Interior 4 06-15-2006 01:13 PM
ram d 50. no spark. Advice needed abe Engine 1 08-14-2005 04:08 PM
496 build up >>> NEED ADVICE terror385 Engine 5 11-17-2003 08:42 AM
1937 Dodge Coupe Ray Suspension - Brakes - Steering 4 12-25-2002 08:09 PM
Tranny Advice Needed 37Ford Transmission - Rearend 5 07-10-2002 09:25 PM
