Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 47 Ford 5 window coupe "hard" headliner
Old 06-15-2006, 11:08 AM
Not A T 25's Avatar
Not A T 25 Not A T 25 is offline
Takes Guts To Cut One Up
Originally Posted by DanTwoLakes
I want to put a "hard" headliner in a 47 Ford 5 window coupe. I know how to do the headliner, but there are no mounting points, either wooden or metal on the inside roof. I need to make mounting points for the luan plywood base so I can screw the plywood to the wooden supports. I will have to make them out of wood, and my question is: What glue or epoxy or contact adhesive should I use and how would it be applied? Any help you guys can give would be appreciated.
Also.......does this car have a metal trim ring that goes around the rear window? This car has trim rings for the windshield, front and rear windows, but none for the rear window, is this how it was originally?
Thanks again.
Dan
Be sure you use a high temp adhesive for the wood and what ever upholstery you apply or you will have sagging problems after the first sit in the sun. 3M makes a spray on adhesive for the upholstery and I would think epoxy for the wood should be good I would back up the epoxy on the wood with screws just to be sure.
