'47 Ford Caps - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2005, 08:17 PM
3bytheknee's Avatar
Question '47 Ford Caps
'47 Ford caps fit really tight to a steel rim. Who has a good trick tool for removing the cap without gouging the powder coating? Something plastic perhaps?
Old 01-03-2005, 09:52 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
I use a large screw driver to pop my dog dish hubcaps off my white caprice. If I was worried about scratches I would just put a piece of duct tape around the end of the screw driver.
Old 01-03-2005, 10:11 PM
packratwrecker's Avatar
Too many hobbies!
To pull the front caps off our Pete's, I have screwdriver, with the end bent about 30*, with a piece of shrink tube that runs up the shaft about an inch, or so.
Believe me, some our our drivers get plumb irate, if you scratch their polished Alcoas.
Old 01-05-2005, 11:48 PM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
I take dog dish hub caps and squeeze them from the sides to make them slightly oblong, then when installing them I will turn them to the widest part and pop them on over the bump in the wheel. That way you don't have to pry hard to get them off.
Old 01-06-2005, 09:39 AM
3bytheknee's Avatar
'47 Ford Hub Caps
Thanks for your suggestions gentlemen.
