47 ford frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2007, 09:06 PM
47 ford frame
is a 2 dr. frame the same length as a 4 dr. frame on a 47 ford car.
Old 09-19-2007, 11:01 PM
Wiki Edits: 31
yes, they are the same length and wheelbase, supports might change if it's a convert were talking about, but probably, were not.
Old 09-19-2007, 11:54 PM
Yes ... a 2 door and a 4 door frame with interchange. ALSO ... a convertible and a sedan delivery have a frame that will fit but they are made of a thicker gauge metal.
Old 09-20-2007, 08:45 AM
Yes
the frames are the same, why do you ask?
Old 09-20-2007, 05:57 PM
Youngster's Avatar
'47 ford frame
As you've already been told, the frames are the same. Don't try to use a Merc frame though. I had someone come to me that tried that switch only to find that his Ford body wouldn't fit on the Merc frame 'cause it was longer.
Youngster
Old 09-20-2007, 08:24 PM
Thats good shouldnt be to hard to convert a 4 door to a 2 door then
Shane
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 07:31 PM
29 Ford...Box the frame? RodGuyinCO Hotrodding Basics 5 12-14-2006 08:38 AM
36 Ford frame repair... CamSweet Suspension - Brakes - Steering 5 07-10-2006 05:20 PM
32 ford frame width at front axle centerline Dirty Steve Hotrodding Basics 4 05-15-2006 08:40 AM
51 Ford -53 Merc frame Dr.Chop Suspension - Brakes - Steering 2 09-25-2002 12:34 PM
