47 ford rear swap (parallel leaf springs) - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-04-2005, 01:24 PM
hi guys, and thanks to all who responded to my question on triangulated 4 bar links......new question: I am tryig to figure out the best way to get my 47 ford business coupe to sit low in the rear. Right now, the car is all stock but have plans on chopping it, adding Mustang ll IFS and an 8" or 9" ford rear end. I already have the setup for the front, but not the back. I can easily buy the kit for the rear, but that takes all the fun out of making it yourself. If I go with the parallel leaf setup, how do I figure out the load rate of the spring? Can i go to the junk yard and get springs and just make my own mounting brackets? Any help on this matter would be appreciated. ONEGALONLY
Old 10-04-2005, 01:45 PM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
A project I had I used mid to realy 70's front Dodge Ramcharger springs for rear springs. They have one reverse eye much like the after market kits and made my own mounts. If I remember right I used I believe around 1400 lb but I can"t remember. It did seem to have nice movement and not to bouncy.Went to a auto parts store under Dayton for parts book. They list 3-4 different springs weights,leafs, and arches. However I traded that project never had a chance to see how it worked out. I might have some info at home somewhere.
Old 10-04-2005, 02:52 PM
Don Meyer's Avatar
I use Crysler 5th ave rear springs on the rear of 41-48 Fords. The ride is great.
Don
Old 10-05-2005, 11:31 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Don
Yep
Don,
Is the 41> wider than the 39-40?
Old 10-06-2005, 07:06 AM
Same here, in the 70's every Ford Rod seemed to be using Holden ifs and Valiant leafs. Mopar springs must be the go either side of the equator. Please mount them slightly downhill at the front and make sure your shackles don't bind at extremes of travel.
rear leaf springs 38 ford 38harry Suspension - Brakes - Steering 2 09-08-2005 04:30 PM
Anyone ever re-arch their own leaf springs? FrankR Suspension - Brakes - Steering 3 07-12-2005 07:57 PM
Rear leaf springs, lowring blocks, and air bags? Cowtown Punk Suspension - Brakes - Steering 2 07-06-2004 05:33 PM
Rear Coil Springs bigjoedo Suspension - Brakes - Steering 3 02-23-2004 02:02 AM
