Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 47 Ford Truck outer door panel replacement
Old 10-18-2012, 01:15 PM
jalopy45's Avatar
jalopy45 jalopy45 is offline
The doors are all the same from 1940 to 1947 and all sizes so a replacement may be the easiest route, but there is no reason you can't make or weld a patch panel in to replace the rust sections with good results. Just watch your heat and do a little at a time.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
The Following User Says Thank You to jalopy45 For This Useful Post:
marvbabco (10-18-2012)
