471 blower engine overheat - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2008, 02:09 PM
Hi I have a 383 stroker with a 4-71 blower the carb is a Carter AFB I am not sure about the jet size and rod size but I think this may be running to lean. Does anyone know the size of the jets and rods or should I get an new carb?
Mike
Old 04-13-2008, 07:22 PM
First thing I would do is get an A/F gauge especially with a blower. You may be surprised by the results. My Edelbroke never ran consistent. It would go from pig rich to too lean with just the slightest tap on the gas. All the tuning in the world and I could never get it dialed in. I finally gave up and got a Predator
Whats the history of the engine? Is it new to you? Did you build it? Do you have an electric or Mechanical fan? with or without a shroud?
Jordon
Old 04-13-2008, 08:21 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Mike
What carb number, cfm. etc. info do you have? You will have to eventually pull the carb and get the jet and metering rod sizes in it and the color of the step-up spring, to get any real helpful information.
Old 04-14-2008, 08:19 AM
First lets discuss the rad, fans and shrouds. If there is a hood on the car, all of these are factors in engine overheating. Was it a fresh build? Was there rust in the block? There is much to discuss when you talk about overheating.
Old 04-15-2008, 09:14 AM
lets cut it up's Avatar
Mike
I would first check your cooling system. Then the fuel system. Is running hot during normal conditions or only under boost? I personally would toss the carter and get either a boost referenced Holley(you can get then in the box now) or a predator (they kinda funny looking ). Start with the most obvious things that could make it over heat first. JMO. TIm
Old 04-15-2008, 05:36 PM
poncho62's Avatar
Wiki Edits: 5
moving this to engine........
Old 04-15-2008, 07:59 PM
BORTI's Avatar
BLOWN 357
engine overheating
First thing to check timing advance curve,make sure its right.I chased a similar problem in my blown small block.Locked the dist. out,runs like a beast now.
Old 04-16-2008, 08:32 AM
XNTRCI-T's Avatar
AKA Lee in KC
A 4-71 is a pretty small blower for a 383. To produce any boost at all the 4-71 would need to be overdriven quite a bit (10%-20%). This is going to add a lot of heat to the intake charge. Fuel mixture and ignition timing are going to be very critical.
Do you know what the drive ratio is on your blower? Count the teeth on the crank pulley and the drive pulley, then divide the number of teeth on the crank pulley by the number of teeth on the drive pulley. Let us know what you come up with.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 12:29 PM
Rebuilt Engine Squeaking, Driving me Nuts! BH69Camaro Engine 24 04-22-2005 08:51 PM
Will no cooling fan overheat an engine? TheRedRS Engine 3 09-09-2004 09:04 PM
New Engine Built & Dyno'd babe_n_indy Engine 69 09-09-2004 07:26 PM
