OK the blocker rod you are speaking of does just that it blocks the fluid from even entering the acc port that is why you have zero pressure at the acc port
Accumulators are used to cushion the shifts and engagements .. and are usually blocked in performance transmissions , there are several ways to do it .
Hope this clears things up for you ...
