48 Chevy Cab Floor Pan Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2012, 11:30 AM
andrewakessler's Avatar
I started working on the floor pan to my 48 Chevy the other day, and noticed the previous owner did some interesting repairs. They seem to have cut out sections of rust then welded fresh steel above the old rusted steel, in addition to welding some steel channeling underneath (please see pics) .
I ground off the rest of the rust on the floor pan, and with the except of a few small holes that can be welded shut it's in good shape.
My question is should I weld the old metal to the new plate to keep water from collecting between the two surfaces, or completely cut out the old metal and weld new steel supports in?
Also, there is a rod connector on the front passenger side of the cab. Does anyone know what this is and if it is needed? I'd prefer to cut it out since it currently doesn't seem to have a use.
Thanks,
_A
ID:	67946   Click image for larger version
ID:	67947   Click image for larger version
ID:	67948   Click image for larger version
Old 09-18-2012, 08:30 PM
bigdog7373's Avatar
Of course it's fast
Make it flat. No stacked pieces or patches welded on top of the pan. Should be smooth and flush.
The Following User Says Thank You to bigdog7373 For This Useful Post:
andrewakessler (09-19-2012)
Old 09-25-2012, 11:56 AM
I got a 1952 chevy truck fron a friend that he started by putting on a s10 frame,I don't like the s10 front end because it looks too narrow.Anybody have a fix ????Has anyone ever cut one and widen it out ??? As far the floor being patched,it depends on if your truck is going to be a show truck are a driver,if its going to be for show then cut it out and fix it right,if its just a driver then weld the douple floor togther to keep the water out and put some bed linner spray over it.Motorboy
need floor pan for 1949 chevy fleetline bob1949 Body - Exterior 12 11-30-2014 09:51 AM
Floor Pan Bead Roll Question dirty dixon Body - Exterior 4 04-14-2011 02:06 PM
1953 chevy truck floor pan 533800 Body - Exterior 6 01-16-2008 06:44 PM
Floor pan question. Hippie Body - Exterior 0 04-20-2007 07:40 AM
where to pick up new front floor pan for a 47 chevy sedan? rat-lac Body - Exterior 4 11-07-2005 06:58 AM
