Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 48 Chevy front sheet metal alignment
Old 03-14-2013, 08:31 AM
bear lake rodder bear lake rodder is offline
Last journal entry: Dash install completed
Thanks for the reply. I decided last night that your suggestion was the only solution (have not heard back from Chassis Engineering yet). The body is mounted on the frame where it has to go and the frame was not modified in any way, except to install the new front and rear suspension. The core support that I am using is the original, but the radiator support that the core support bolts to is from Chassis Engineering. Last night I fabricated a 1/4" steel plate to move the core support toward the rear by the 1.25" I needed to bolt stuff up. I installed the core support and the fender liners bolted up. I have not installed fenders yet, but will post to my project journal when I do.
Thank you for the reply to my post!
Bear Lake Rodder
