Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 48 Chevy front sheet metal alignment
Old 03-18-2013, 06:46 AM
bear lake rodder bear lake rodder is offline
Last journal entry: Dash install completed
I moved the core support back as I mentioned previously and this past weekend I bolted up the fender liners, baffles, and front splash pan and then test-fitted the fenders. Everything bolts up pretty close, pending the inevitable adjustments.
Thank you for the replies and suggestions!
Bear Lake Rodder
Name:	Fender liners, baffles, and front splash pan all installed after core support was moved back 1.2.jpg
ID:	72362   Click image for larger version
Name:	Fenders fit pretty well, but just getting started with test-fit. Mar. 16.13.jpg
