Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 48 chevy p/u door adjustment
Old 04-14-2011, 01:17 PM
cornfieldcars cornfieldcars is offline
Wow...really appriciate all the responses. The door is lined up very well. Before installing the latches the doors were just right. With the latches installed the doors shut with little effort. I'm thinking you were right in the first post Martin. It seems like the striker needs to come out a little, but when it is latched tight, the seams and everything are all lined up just right. Wouldn't moving the strikers out misalign the door? Not to mention I don't have the rubber in yet which will make this problem even worse. Could the hinges be misaligned causing this? thanks again
