48 coupe suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2013, 01:54 AM
48 coupe suspension
I jus bought a 48.ford coupe....I want to upgrade the suspension so it will hold up to efi 5.0 but dnt know what I should do ...someone told me I could use a foxbody suspension but im not sure...any help would b apperciated
Old 04-26-2013, 07:42 AM
BOBCRMAN@aol.com's Avatar
I have owned several of these coupes. Much can be done with the stock front suspension. But for a good ride and better road handling go with a Must ll type front end. The crossmembers and brakes can be had from http://www.chassisengineeringinc.com/ Speedwaymotors.com or Fatman fab and several ohers.
Then comes the rear end/rear suspension issues. By the time you are finished you will be well versed in early Fords.. and broke!
Old 04-26-2013, 01:28 PM
48 coupe
So do.u think the orginal crossmember will hold up and I can jus upgrade everything else with the orginal crossmemeber
Old 04-26-2013, 03:56 PM
I have run the stock front type suspension/crossmember with a 425 Buick and a 461 Big block Chevy and both cars held up well.
Old 04-27-2013, 09:02 AM
boatbob2
48 ford coupe
Hi,i have a 48 ford coupe also,i put in a FATMANS IFS,great,PAY ATTENTION to the directions.IF youre using an automatic,the center crossmember will need to be widened,so that if you ever have to rebuild the trans,you wont have to pull the engine,,(I had to modify mine,(widen the center) that hat section on top of the crossmember wont work (too narrow) I had to make a new top section,I hope you are pulling the body off the chassis,it is LOT easier to work on...
48 coupe, ford, suspension
35 Plymouth Coupe Steering / Suspension new2PlyHR Suspension - Brakes - Steering 6 03-16-2012 10:32 PM
What suspension for a 32 ford coupe? roysaric Suspension - Brakes - Steering 27 08-30-2011 05:04 PM
37 Chevy Coupe Suspension Robert08 Suspension - Brakes - Steering 1 03-06-2009 06:33 PM
35 Dodge coupe suspension ? Thirty Over Suspension - Brakes - Steering 5 05-07-2008 11:54 AM
Suspension options for 41 ford coupe Thunder Road Suspension - Brakes - Steering 1 09-15-2006 05:22 AM
