48 ford cab on 66 ford frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-18-2012, 08:51 AM
would itwork to pu a 48 f1 cab on a 66 f250 ford 4wheel drive frame or would some other frame work better can be emailed hotrodhaven319gmail.com
Old 02-18-2012, 09:44 AM
poncho62's Avatar
Wiki Edits: 5
The width would probably be way too wide......If I was going to do something like this, I would get a more modern drivetrain, easier to get parts for.
Old 02-18-2012, 05:09 PM
da34guy's Avatar
Get your tape measure out.
It'll tell ya all ya want to know.
Old 02-18-2012, 05:46 PM
I saw a 37 Ford cab,hood,radiator shell, fenders, and running boards installed on a 1 ton Chevy dually running gear that had been extended to become a roll back behind an old Freightliner sleeper that had been grafted to the back of the cab. Very neat installation. The 48 cab is at least 2.5" wider than the 37 so it should go onto the Ford frame with some high level fabricating skills. Your PU fenders and larger truck wheels and tires may be a challenge since the 37 cab I referenced was from a big truck thus the fenders were larger and roomier.
Trees
36 Ford Pickup on a Ford Ranger Frame? Fasteddy General Rodding Tech 21 12-08-2012 11:25 AM
32 ford on a 30 frame hotrod charlie Body - Exterior 10 02-19-2009 06:36 AM
'98-'08 Ford Ranger Frame w/ '37 Ford Body? jbundick Hotrodders' Lounge 8 12-28-2007 05:31 PM
47 ford frame hottrodz Suspension - Brakes - Steering 5 09-20-2007 07:24 PM
Ford Frame VIN werktrux Hotrodders' Lounge 0 11-07-2002 03:03 AM
