48 ford hot rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2009, 09:45 PM
48 ford hot rod
i'm building 48 ford tudor hot rod and i have a 350 sbc 4 bolt main 700r4 tranny 10 bolt chev rear end but i want to use the original x frame. do i have to cut the frame to fit the engine & tranny
Old 10-21-2009, 11:29 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Are you concerned about the position of the 'X" and the overall length of the engine/trans? OR physically getting the SBC between the rails?
Better get out your favorite tape measure...
Old 10-22-2009, 08:12 PM
48 Ford
Hey C10, I Really Don't Want To Cut The X Could I Lower The Tranny And Lose The Lower Piece Under The X Maybe Flip It Over And Re Install It
Old 10-23-2009, 12:09 AM
C-10's Avatar
Revolution Calling
I have a friend with a newly aquired '49 Ford with a flathead. I do not know what to do right off hand to get your combo to work. I'm sure it can be 'done' and HAS BEEN done in the past. It would be safe to say there will be some welding and fabrication in your future. I can look under the '49 and size it up, but it's not at my shop. That is if the '48 & '49 are the same.
Maybe there is a kit? I dunno.
Old 10-23-2009, 01:03 AM
techinspector1's Avatar
Wiki Edits: 326
They're not. '48 was the last year for buggy springs.
Old 10-23-2009, 01:17 AM
C-10's Avatar
Revolution Calling
Okee-doke then. Well, Hollywood will have to measure once and cut twice.
Or is it the other way 'round?
Seems like his engine/trans would fit without hacking up a perfectly good frame.. I have no real good reference.
Old 10-23-2009, 04:24 AM
moontanker's Avatar
Last journal entry: My 32 Ford pikup..
Nah ,itl fit no cuts
Get er done
Old 10-23-2009, 03:35 PM
48 Ford
Thanks Gentlemen. I'll Keep All Of Ya Posted On The Progress
Old 10-23-2009, 05:18 PM
boatbob2
48 Ford COUPE....
Hi,i have a 48 ford long door coupe,with the same engine and trans that you are using.i had to cut the center of the X out,because that was the only way to remove the trans without taking the engine out too.i only cut the center 12 inches on both sides,then rewelded each side front and rear to itself.making a kinda lazy sideways V.then i made a nice strong cross member for the trans to sit on,.while tying both sides together..
Old 10-23-2009, 08:08 PM
Ford Hollywood
Hey Boatbob2 Do You Have Any Pics On How You It Looks
Old 10-24-2009, 09:00 AM
48 Ford
Looking For Any Pics Of Chasis Work On Installation Of 350 Sbc 700r4 Tranny And 10 Bolt Rear End Keeping The Wheel Base At 114"
Old 10-24-2009, 05:28 PM
boatbob2
HI Canada.....
Hi Ford Hollywood...i have photos,but i cannot email them. send me your mailing address,and ill mail them to you...IF you return them to me !!! boatbob2
Old 10-27-2009, 02:10 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
This will give you an idea how it can be built.
Name:	Engine installed.jpg
ID:	41581   Click image for larger version
Name:	frame demensions.gif
List all of your cars HERE! Carbed95GT Hotrodders' Lounge 289 11-09-2011 06:43 PM
ford susp on hot rod playsinthedirt Suspension - Brakes - Steering 33 04-02-2007 10:18 PM
2 new forums: Hot Rod Art and Off-Topic Jon Hotrodders' Lounge 2 09-23-2005 03:50 PM
31 ford hot rod WilderRods Engine 5 02-02-2005 05:15 PM
