48 ford truck rat rod channel - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2007, 09:24 PM
48 ford rat rod truck
Hey got a 48 Ford truck that I am wanting rat and get real low to the ground and was wondering about channeling this truck not sure how to go about it?!Can anybody help me out on understanding this?
Old 09-24-2007, 09:45 PM
Do you care if you go to IFS if you can get it really low?
Shane
Old 09-24-2007, 11:24 PM
Countilaw's Avatar
Cox Custom Cars
Go with the independant front suspension and dog leg the rear of the frame is the best way to lower it. That way you get the frame lower and save the room inside the cab that you would lose channelling it. The cab is small enough without running the frame through it.
Old 09-24-2007, 11:53 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Here is a quick overview of one way to channel your truck - brace the inside of the cab so it will not change shape when you remove the floor, cut out the floor and body and floor braces under the cab, drop your body down to ride height and re-weld the floor and bracing back to the cab at the higher height.
Here is another way a 46 pickup was done using a donor cab:
Interesting approach at channeling an early Ford.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 09-25-2007, 07:56 AM
s10 chassi ifs and factory z'd
Shane
Old 09-25-2007, 06:14 PM
48 Ford rat rod truck
Hey thanks for all the info.Thinkin about building my own frame that is z`d and able to hold an I beam front axle.Any advice?
Old 09-26-2007, 01:57 AM
home brew's Avatar
You could build a T bucket frame with your own dimensions for your truck. Check out this link:
http://members.tripod.com/~Jackak10/tbucket.html
Old 09-26-2007, 06:35 PM
Thanks Home Brew very helpful.
66 ford truck twin i beam lowering tech igotachevyor2 Suspension - Brakes - Steering 15 12-16-2011 08:45 AM
looking to decode a vin # ford truck since 73 Dubz Hotrodding Basics 6 02-12-2009 02:28 AM
51 Ford Panel Truck BAD TO THE BONE 413 Introduce Yourself 4 01-02-2006 07:38 PM
My 48 Ford Truck Big guy Introduce Yourself 2 11-19-2005 08:57 AM
60 ford truck buckshot_59 Body - Exterior 2 10-05-2005 12:53 PM
