Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 07-03-2008, 10:44 AM
48GMC rod 48GMC rod is offline
48 GMC original lead
I have a 48 GMC and there is lead from when they manufactured it on the cowl section where it meets the rest of the body. My question is do I or don't I remove this and replace with the newer polyester fillers available today? Also if I leave it, will I run the chance of the lead cracking and splitting my paintjob down the road? Anybody with a working knowledge of the factory lead please chime in. thanks
Old 07-03-2008, 11:36 AM
oldred oldred is online now
re: 48 GMC original lead
Is it still solid after 60 years? Why would it crack now? The newer fillers are really good stuff and do have advantages in application and such but are they actually better than lead? I seriously doubt it!
Old 07-03-2008, 01:12 PM
Sorry I am just paranoid because there was a place that was fixed on the upper back part of the cab that had cracked and split...What causes the lead to split apart anyway?
Old 07-03-2008, 02:58 PM
Holder350's Avatar
Holder350 Holder350 is offline
Auto Parts Professional
extreme temps (cold) can cause it to split but most of the time it is so flexible that it simply warps in and out of shape.
the old Lacquer paint seems prone to crack anyhow....the newer poly paints take a bit more abuse from temps.
Thats my understanding anyhow
Old 07-04-2008, 09:42 AM
jimmy1 jimmy1 is offline
I'am doing a 51' and had alot of work on the cowl and windshield channels and although the modern fillers are great this is a high stress area in these cabs especially were the roof pillar and lower windshield channel meets the cowl at the belt. Yes its more work! but worth it IMO. Just make sure you don't lead in the little square drain holes in the windshield channel corners " they serve a purpose''! Like old red said if the lead is good after 60 years nothing short of a torch will take it out, just add to it.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "48 GMC original lead"
1957? GMC truck impala59 General Rodding Tech 13 10-27-2008 09:32 AM
Epoxy primer over lead? Slickriffs Body - Exterior 2 09-13-2007 04:31 PM
Chevy v.s GMC truck A-arm lengths? Gearhead forever Suspension - Brakes - Steering 6 09-10-2004 11:15 AM
GMC 1/2 ton A-Arms v.s. Chevy? Gearhead forever Suspension - Brakes - Steering 1 09-23-2003 08:49 PM
New Member Introduction - 48 Chevy Rodder 48 Chevy Rodder Hotrodders' Lounge 0 10-20-2001 03:04 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
