48 GMC pickup to S10 frame swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2007, 02:42 PM
I'm wondering if anyone knows where to find a good step by step for swaping a 1948 gmc pickup to an S10 frame, I've got the cab mounted, about to put the box on, (i need to cut it down its a long box) also puting in a chevy 350 with a 700r4, could use some advice on that also. thanks
Old 03-19-2007, 03:51 PM
Originally Posted by pioneer-auto
I'm wondering if anyone knows where to find a good step by step for swapping a 1948 gmc pickup to an S10 frame, I've got the cab mounted, about to put the box on, (i need to cut it down its a long box) also putting in a chevy 350 with a 700r4, could use some advice on that also. thanks
I am reading myself to do the same swap including the 700r4. try some of these sites
http://chevytrucks.org/tech/s10_frame_swap.htm
http://www.ad-engineering.com/
http://www.jagsthatrun.com/
I bought an 85 s10 and an 85s10 blazer for $400 I have a 53 chevy and just working on time and getting other projects out of the way to get started. I have 305 laying around and a possibly good 700r4.
keep us updated on your project. Ed ke6bnl
Old 03-19-2007, 07:13 PM
i'm planning a similar project. i'm putting a 52 dodge pickup on an s-10 frame. only i'm going to leave the v-6, 5 speed ,all the wiring, pedals, floor, etc of the s-10. so i'm really just going to take the s-10 skin off the cab and replace it with the skin of the 52. then swap the bed and front clip. as far as putting the v-8 into your chassis, several kits are available. as are headers. i'm going to use the firewall and floor section of the s-10 so all the pedals and steering are already in place. cutting the bed down is straight forward. mounting the front clip should be pretty simple too. i'm presently building 4 s-10 based hot rods. if you need detailed pics of have detailed questions let me know.
Old 03-20-2007, 03:24 PM
Don't use extra cab S10
WOW Thanks for all the help, I found some bad news for me, I used the extra cab short box off the S10, I need to shave off 5 inches in the middle, the wheel base is too long, (bummer) it can and will be done, just one more thing to do. word to the wise, for this project stick with the regular cab long box S10.
Old 03-24-2007, 05:33 PM
All I can do is offer my website as a guide. I have pics and info.
www.geocities.com/lakota_circle_dancer/swap1
USING LATE 80'S FRAME FOR A 1937 FORD PICKUP DIGGER Body - Exterior 24 08-24-2013 07:25 PM
Blazer buckets into 89 s10 pickup gothrod87 Interior 2 03-10-2007 09:42 PM
55 chevy truck frame swap john sekulich Introduce Yourself 1 02-20-2007 07:15 PM
GMC Pickup Parts RKesner Hotrodders' Lounge 2 02-22-2003 10:08 PM
s10 frame question mitmaks Body - Exterior 7 02-04-2003 03:53 PM
