Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 48 jeepster swap
Old 10-06-2012, 08:01 AM
timothale timothale is offline
Wiki Edits: 27
pinto rear to 5 bolts
I don't know if early mustang 5 bolt axle shafts and 5 bolt brake drums are a direct fit or not, That way you could keep the Willys wheels , hubcaps and beauty rings. On mine I used ford centers and wider buick hoops for the rear and used some VW spring clips i bolted on so i could keep the Willys hubcaps.
