Hotrodders Bulletin Board
#1
48 Lincoln disc brakes??
Hi;Anyone have any idea for disc brakes on this.Apparently the back plate is different from the 48 ford or could probably use some of those disc kits.Heard there is a ford P/U with a pattern that would bolt to the 48 axle and a wheel bolt pattern same as the old Lincoln maybe early 70s.Would I need to change master cylinder if did this?Who sells those power boosters that fit under the ford for these master cyl's?Would be nice to split the system to the dual system like the newer cars.Very disconcerting to break a line coming up to a busy intersection in O/D.Thanks!
#2
re: 48 Lincoln disc brakes??
Definitely dual master cyl. system. I would suggest grabbing a copy of Street Rodder Magazine and Rod and Custom Magazine. There are advertisers in there. |
Back to top |
Similar Threads for: "48 Lincoln disc brakes??"
| Lincoln rear disc brakes | '45 Ford | Suspension - Brakes - Steering | 7 | 08-30-2007 04:01 PM |
| Does the 76 Lincoln Continental come with 9" and disc Brakes | Tri5Nerd | Transmission - Rearend | 8 | 08-23-2005 11:22 AM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
| Lincoln Rear Disc Brakes | Bgener | Suspension - Brakes - Steering | 2 | 12-17-2002 01:43 PM |
| 1978 lincoln rear disc brakes | FAIRLANE DUDE | Suspension - Brakes - Steering | 1 | 10-07-2002 05:36 AM |
