487x - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2009, 04:43 PM
BackYardRacer
487x
dose an one know what kinda flow numbers 487x head put out and how many cc's the runners are i have to sets of these head and i know they are 1972 lt1 heads in very good shape i've been thinking about using them
Old 04-06-2009, 05:17 PM
techinspector1's Avatar
Wiki Edits: 326
Don't hold me to this, but I think the intake runners are 161 and the exhausts are 65. They're fairly heavy castings, so shouldn't crack as easily as some other production castings. '71-'72 was the tick-over for unleaded fuel, so the exhaust seats may be induction hardened or they may not be.
Old 04-06-2009, 06:50 PM
BackYardRacer
i've been searching for hours for some flow data on these dose any know of a page that might have some flow numbers one these heads alot ppl have them and no one has put them on a flow bench of some thin
Old 04-06-2009, 10:06 PM
ericnova72's Avatar
More for Less Racer
Tested a set of the 487x something like 15 years ago before porting them just to know how they were stock, for a reference point. I don't have the exact #'s in front of me, but i remember they were in the high 150's cfm intake and mid 120's on exhaust with 1.94-1.5 valves. They ended up around 220 intake and 180 exhaust after porting with 2.02-1.6 valves.
These were also commonly used on 4-barrel truck engines with 1.94-1.5 valves, which is where mine came from.
Old 04-06-2009, 10:09 PM
Wiki Edits: 326
Picked this up off the corvetteforum....
"Brzezinski published stock flow numbers for the 492 head that they report is is very similar in flow to the 487's:
Lift In Ex
.1 59 57
.2 120 107
.3 166 125
.4 192 196
.5 196 141
.6 199 141
They get 10% more flow with minor port cleanup work, and ~20% more flow with a little more port work. Randy Brzezinski is a stand up guy (in my excellent business experience with him) so I expect these numbers are valid."
Old 04-06-2009, 10:39 PM
BackYardRacer
thanks for the info then i think they should make 410 hp with a little bit of work and a dome piston what do you all think
Old 04-06-2009, 10:50 PM
BackYardRacer
the head i got came off a 1972 el comeno with 4bl carb 1.94 1.50
lots of pple say they have 2.02 but i have 2 pair and both have the 1.94 in them dose any one want a set no work has been done to eather pair
Old 04-07-2009, 12:54 AM
ericnova72's Avatar
More for Less Racer
With porting you should be able to make the 410hp # with enough compression in a 350. The ported set I use went on a short-rod 383 at 9-1 compression w/ solid lifter cam in a 3700lb car with 4;10 gears and 2600 stall. It went 12.50's at 110 mph in the 1/4 mile, driven to the track (75 miles away) on pump gas.
487x heads question stfinney Engine 15 07-31-2012 11:12 AM
487x ronster67 Engine 2 05-30-2006 06:50 PM
SBC 487X Heads-What's the X for? acr Engine 1 11-07-2004 09:06 PM
Help with 487x heads stfinney Engine 6 06-17-2003 10:05 PM
487x Heads??? stfinney Engine 2 11-21-2002 08:24 PM
