49,50 olds taillights - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2007, 08:47 PM
Has anyone used '49 or '50 Olds taillights on a '39 or '40 Ford? There is a bezel above these lights. I'm not sure if they would look okay or not. Thanks in advance, Rod
Old 11-26-2007, 10:12 AM
If the lights will fit the contour of the top of the Ford fenders and face the rear as required they could be a working deal there. EVen you have to make a bit of a trough for them to sit in.
I'm sure these have been used before, probably in the early-mid-50s on asome full custom 39 DeLuxe or 40 Ford.
Old 11-27-2007, 08:46 PM
The bezels would definitely have to be modified. The long tail of the bezel will not fit the contour of the 39-40 Ford fender.
Another alterative would be to make an aluminum bezel for the lens only if you want to use just the lenses.
Old 11-28-2007, 06:36 PM
Thanks, guys.
Hey guys, thanks for the response on the Olds taillight question regarding my '39. I appreciate it. Rod
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
S10 to '49 Olds? grouch Suspension - Brakes - Steering 100 10-22-2010 03:57 PM
frames 37 chevy going on a 38 olds 38 old coupe Suspension - Brakes - Steering 0 05-24-2004 01:45 PM
Camaro-T/A motor mounts and Olds Questions Hot_Rod_Faith Engine 8 01-15-2004 01:01 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
