49 - 54 Pontiac help pls - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2007, 10:14 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
I want to upgrade the front brakes and suspension on my 41 Pontiac.
The 49 -54 takes the same spindle as my 41, so I can upgrade to bigger drums, brakes and cylinders. these years also switched to tube shocks, and I suspect the caster specs moved to a more positive stance.
Can anyone provide alignment specs for the 49 to 54? Frame configuration and specifications? (might be in a shop repair manual). Pictures and specs of the upper and lower A frames? (may be in a parts manual)
I would be interested in buying the entire front end, hub to hub, if anyone has subframed one and has the old parts.
Old 04-14-2007, 10:29 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
Would that share the frame and suspension of a '49 Chevy? If so, this might help:
http://chevy.tocmp.com/1949_53shop/index.htm
Old 04-14-2007, 10:40 PM
oldguy829's Avatar
Wiki Edits: 88
appreciate the help grouch, but no. Chevy's top hat frame is completely different. Some of the bushings, bearings, etc. from the same year Olds will interchange, so that might help.
Old 04-14-2007, 10:59 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
It just so happens that grouch spent a whole bunch of time and effort and scanned his manual for his 49 Olds.
It is available FREE at:
http://edge-op.org/1949_Oldsmobile/
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-14-2007, 11:20 PM
grouch's Avatar
Wiki Edits: 2
For some reason, I had it in my head that Chevy, Pontiac and Buick shared the same frame and suspension and that Olds was the oddball in the family. If the Olds and Pontiac are similar, then you're in luck and just follow the link home brew posted.
Old 04-15-2007, 12:37 PM
oldguy829's Avatar
Wiki Edits: 88
re: 49 - 54 Pontiac help pls
Awsesome, that is exactly what I was looking for. Haven't had a chance to really study it, but first glance, it appears Olds still had the knee shock in 49 whereas Pontiac had already gone to tube shocks.
This is exactly what I was hoping to find for the 53/54 Pontiac. The 53/54 Olds might work too.
With this detail of information, I could figure it out. thanks grouch.
anyone got exactly what I need?
don
Old 04-17-2007, 08:47 AM
oldguy829's Avatar
Wiki Edits: 88
Still need to confirm the 49 - 54 pontiac brakes and front suspension will fit my 41. Can anyone help?
400 sbc vs 400 pontiac Artemis Entreri Engine 52 09-08-2010 07:17 PM
'54 Pontiac Engine Swap Monkey Hotrodding Basics 10 04-23-2007 11:29 AM
Pontiac will drop GTO this year ckucia Hotrodders' Lounge 10 02-22-2006 10:44 PM
34 pontiac 81 camaro subframe install ? mobythevan Suspension - Brakes - Steering 7 05-19-2005 01:17 PM
Pontiac xxx(madmax )xxx Engine 13 12-05-2002 08:03 PM
