49 chev steering wheel button help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2014, 09:33 PM
tapkoote's Avatar
Last journal entry: like a little kid
I can get it to spin right and left.
Can't get it off, does it need a pry bar?
Thanks Pat
Old 01-14-2014, 05:22 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Moving this to General Rodding tech.
Dan
Old 01-14-2014, 06:26 AM
tapkoote's Avatar
Thanks
I've searched how to pull the steering shaft but,
they don't start at 101.
Not even at the manual. Don't want to screw it up.
Old 01-15-2014, 07:13 AM
Guest
You mean the horn button? I've done a 48 & 52 truck and the horn button has fingers on it and it just pops off, if i remember right. The steering wheel itself is held with a nut and you'll need a puller, it isn't all that tight.
I don't remember the horn button being round, kinda flat on the bottom, but that may be the difference between trucks and cars.
Old 01-15-2014, 10:14 AM
Don't EVER use anything like a screw driver or ANYTHING to remove a horn button from a vintage wheel. They ALL come off very easily and even the tiny bit of prying will likely crack or break the hardened plastic.
My Rambler has a small set screw in the wheel that has to be loosened up but even then the button needs to be rotated to remove.
Some are held in with a simple spring like clamp all the way around with little fingers that are grabbing it, all you do is pull it off. But what ever, DO NOT use any kind of tool to pry it.
On the wheel off the column, many old cars don't have a place to put a puller, like my Rambler. On those if you loosen the nut up very loose then with your feet down on the floor boards pull up on the wheel as hard as ou can twisting it side to side it will come loose.
Old 01-15-2014, 12:58 PM
tapkoote's Avatar
this is the wheel
I'm fairly sure this is a dust cap since it has a horn ring.
It's probably pot metal, don't want to damage it.
Thanks Pat
Old 01-15-2014, 02:36 PM
tapkoote's Avatar
update
The inside of the opening had been painted,
made it a tight fit.
Turning it left made it tighter, so I turned it right.
There is a notch on top and a tab on the cap,
spin it 180* to remove.
Pat
steering wheel/car vibration and slight steering wheel shake side to side. Stumpman Suspension - Brakes - Steering 11 12-27-2013 02:27 PM
My NOS steering wheel and horn button. MARTINSR Off-Topic 6 09-01-2011 11:20 PM
Dodge push button shifter on Chev trans Tcat55371 Transmission - Rearend 4 01-11-2008 07:05 AM
Horn Button on Lecarra Steering Wheel djboen Electrical 2 05-22-2006 06:35 PM
Putting on new air bag steering wheel on a older steering collumn. CruisingRam Interior 10 12-20-2004 04:34 AM
