49 chevy covering the hole left by the gas tank filler hose. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2012, 02:31 PM
Last journal entry: All paint hiccups fixed!
I have a 1949 chevy pickup. I've moved the gas tank out of the cab and under the bed. I was hoping there would be a 'patch panel' piece that I could get to weld over the hole left by fill tube that used to stick out of the cab. Any suggestions on the easiest way to do this? If I have to fabricate the piece it's going to be a pain in the butt cuz it's curved in both directions, up and down AND sideways.
Any suggestions would be very much appreciated.
EZ
Old 10-03-2012, 07:19 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
If you have a peice of pipe about the size of the gas filler hole. Set your tin for your patch over the top end of the pipe. Now you can hammer a crown both way in your patch using the pipe end for support.
Old 10-03-2012, 07:22 AM
Wiki Edits: 27
battery sawsall
Go to a pick your part and cut out a piece above the hole and you will have minimum hammer work , My son calls it cut and paste custom work.
Old 10-03-2012, 09:36 AM
It's such a small piece fabbing something like that does't get any easier than this one. Get your feet wet fabricating, this is the perfect start!
Old 10-03-2012, 10:07 AM
Thanks for the input, just the info I was looking for. I'll post a photo of the process of it in my journal.
Old 10-03-2012, 10:12 AM
Do what MARTINSR said. If the area had a really deep crown, cut a wedge out of the flat metal, weld it back together, and then finish the crown.
truck bed gas filler hose question swampyankee General Rodding Tech 4 09-10-2011 12:27 PM
fill the old gas filler hole in truck body Studedean Body - Exterior 2 07-14-2011 12:56 PM
Gas Tank filler neck HaydenP Hotrodding Basics 3 06-14-2011 11:56 PM
filler neck hose for main gas tank Arillious Engine 5 12-14-2008 03:45 AM
Gas tank filler guba_unus General Rodding Tech 4 05-13-2008 06:47 PM
