49 chevy truck Chassis swap 80 Camaro questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2009, 10:48 PM
49 chevy truck Chassis swap 80 Camaro questions *UPDATE with Pics
Ok I bought a 1980 Camaro and We will be picking up the 49 Chevy truck tomorrow. So I have a few questions.
1. What rear end came with this truck and can I use the Camaro rear end instead?
2. Same question for the rear suspension.
3. Does anyone have a step by step for doing this chassis swap? New Interiors thank you for your help so far.
4. Should I use the wiring harness from the Camaro?
5. What else can I use off the Camaro?
6. Brake system for the rear and suggestions?
I know I may be asking alot here but this is my first time to swap a chassis and work on a vehicle older than me. I'm really pumped about tackling this though. I would appreciate any input, links, pictures and suggestions for doing this project. This is why I love these forums how did we ever get along without them.
Thank you in advance
Mark
Old 09-03-2009, 11:14 PM
"Chassis swap"? The Camaro is a unibody and has no "Chassis".
Old 09-04-2009, 01:15 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Brian doesn't the 2nd generation Camaro have a 'sub frame' in the front that is sometimes used for this type of thing? Like, say to ditch the straight axle?
Blankenship: You can use a lot of things, column, brakes, PS, seat, it's up to your imagination. I'd probably simplify the wiring from the '80 and use the more modern fuse box.
Best of luck.
Old 09-04-2009, 06:05 AM
poncho62's Avatar
Wiki Edits: 5
I used a 76 Nova for my 51 Ford F1........The Camaro rear should fit, probably have to move the spring perches. I used the F1 springs and made new shock mounts.....Also used the master cylinder etc from the Nova. .....Grafted the Nava front clip top the Ford frame.
ID:	40413   Click image for larger version
Old 09-04-2009, 07:04 AM
techinspector1's Avatar
Wiki Edits: 326
Here's an article I wrote for the wiki, putting my thoughts on paper for a young fellow who wanted to do a frame swap on his International pickup truck, using a Dakota frame. It is by no means a step-by-step instructional, but you may gain something from reading it....
http://www.crankshaftcoalition.com/wiki/Frame_Swap
The Following User Says Thank You to techinspector1 For This Useful Post:
djhalladay (01-30-2015)
Old 09-04-2009, 07:54 AM
You are right that the Camaro has a sub frame you can splice onto the Chevy truck frame. I have done it, I do NOT recommend it.
Mark, listen, that truck has a Beautifully simply frame, leave it as is and work on other mods. I have had a truck like that for 35 years. And the biggest mistake I think I ever made was putting the Camaro clip on it. It was done right, it was just "not right" putting it on there. It is too wide, it requires some serious modification to the inner fenders and rad support, it is just "not right".
There are a zillion bolt on modifications available for that original frame. The rear end will bolt in right on the stock truck springs. There are springs available that will lower the truck and give it a better ride.
You need to make up your mind what you are going to do with the truck and how far you are going to go. You can make a super nice little hot rod with very little mods and be out having fun in a very short while. Or you can do a complete rebuild with four wheel independent susp and a blown big block.
But using the stuff you have from the Camaro is not the right way to go if you ask me. JUST BECAUSE you have it is usually a big mistake.
There are MUCH better components out there for your truck.
Old 09-04-2009, 08:10 AM
life is a temporary assignment
Sorry... But there's nothing you can do to that front end to make it ride as good as the Camaro.... Yes you can make it ''better'',But no where's close to the ride you get with the Camaro/Nova...If you want one a little narrower, Go with the nova..It's 1.5'' narrower hub to hub...I do recommend the Nova over the Camaro..It is a lot of work to do a clip...But to me,It's a much better ride when done right.. Make sure you remember it's a job to do it..Good luck..
Old 09-04-2009, 09:45 AM
31 five window
Last journal entry: grill and rear end
If money is not a problem,Martinsr is right. There are many MII style front suspensions that work very well but they are expensive.If like most of us you are on a tight budget then the Camaro or Nova is a great way to go. I speak from actually doing it.Just remember the rear came with a torque tube rear so the center bolts on the rear springs are in front of the rear end. This means when you put the Camaro rear end in you will have to make custom perches to locate the rear behind the bolts to keep the wheels centered in the wheel well.Hope this helps.Martinsr,How about some pics of the clip job on your truck?This might help him to see what it looks like so he can make a more informed decision.
Old 09-04-2009, 09:46 AM
I rode in my friends 53 just a little while ago with a Camaro clip and was blown away with how well it handled and the ride, this thing just gave you a huge adrenaline rush. He did not do the clip himself and it was not done right it was just welded to the frame not reinforced or anything so he will be redoing it. He gave me one hell of a ride And I'm convinced this is the way to go. Thanks everyone for your comments if there is anything else you find please let me know.
Thanks
Mark
Old 09-04-2009, 09:51 AM
Martinsr, I would love to see how you did it too.
Old 09-04-2009, 10:38 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
i have done many of the gm clips. they are by far the best thing to use . the ride and drive is much better than the mll . i have never had a problem with it. done right is is as safe as it can be. i do not do cut and butt. the trick is to put a 1 in spacer under the forward cab mount. this will raise the front for clearance of steering and core support. i run 225;s on front and they do not hit.
Name:	56 done resize.jpg
Old 09-04-2009, 11:11 AM
I do a cut and butt, in a way... But also plate all the way around the butt, And pass each side of the butt about 6'' then flow it out into the two frames..And box the old frame back some..
Old 09-04-2009, 11:43 AM
chassis swap
u can use a extended cab s10 chassis it works great u have to add motor and trans mounts, running board mounts, and cab mounts evey thing else works great
Old 09-04-2009, 11:47 AM
I like to avoid the s-10 frames as much as possible.. Too much trouble putting big motors in them.. And I don't fine the ride as good as the Camaro/Nova..
Old 09-04-2009, 01:29 PM
shine's Avatar
SPI Thug
i guess i always do overkill. this is how i have done them for years . fast and easy . i'm doing some stuff with s10's now. using s10 front clip on my 46 ford. the chassis mate up just under the front seat. has about 8 in of overlap.
frame swap for 1950 chevy truck truck1950 Hotrodding Basics 39 06-24-2015 02:40 PM
700r4 into 72 chevy truck... A few questions kookykrispy Transmission - Rearend 4 12-16-2008 02:21 PM
rearend swap 56 chevy truck StLouisDave Transmission - Rearend 1 10-07-2008 07:44 PM
Camaro rear end for a 1950 chevy truck chevykid33 Transmission - Rearend 4 01-26-2008 11:54 AM
Camaro Rearend in '55 Chevy Truck BillCull Hotrodders Site Suggestions and Help 3 02-01-2007 05:33 PM
