49 chey sendan delivery - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2006, 07:16 AM
Lets Rock'n Roll
Considering on using a 87 S/10 chassie under a 49 chevy sedan delivery body. What do ya think?
Old 02-15-2006, 07:54 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Measure the wheelbase and the track width on both...then take a good look at the rear kick up part on both frames and tell us what you think.
Old 02-15-2006, 07:56 AM
edwardjba
Not really it is a 48 though
Ed
Old 02-15-2006, 10:59 AM
Lets Rock'n Roll
I've pretty much have all those details checked out and I will have to do some fabricating but that isn't a issue we me as I have the means and ability to do what is needed. The big reason I've chosen the S/10 is I have one that I used to drive and still have it in the back yard.
And ED. it is a 49 or 50 as there the same. I intend in posting some pic.soon on the progress I've made so far.
Thanks
Old 02-16-2006, 06:11 AM
ed
My plymouth is a 1948
thanks
Old 02-16-2006, 08:34 PM
Old Timer,
I just put a Ford F-1 pick up on an S-10 frame. The rear kick up is 7 inches higher than the center. The front is 3 inches higher than the center. I have a website about the swap with pictures and info that could help.
www.geocities.com/lakota_circle_dancer/
The wheelbases on the Shortbed/Longbed/Extended Cab are 108"/117"/122" . The width of the axles are 55" from wheel mount to wheel mount, or 48" from flange to flange (backing plate to backing plate). If you need a wider rearend look into an S-10 4X4 rearend, it's 4" wider.
Old 02-17-2006, 06:06 AM
Lets Rock'n Roll
Hey thanks Lakota,
The chassis swap is me thinking ahead as the body was rooted out so bad I had to put new floors, rockers, door post and quarters before I can lift it off it's original chassis. Your in put will help as the s/10's I have are still under snow and waiting for spring. I have a two wheel extended cab and a 4x4 blazer so as for the rear end goes and using your info. maybe I'm covered?
Again Thanks
Old Timer
Old 02-24-2006, 03:40 PM
Lets Rock'n Roll
This is it in the rough with progress phtos to come soon.
Old 02-26-2006, 04:41 PM
38 special's Avatar
Be the MIRACLE!
Last journal entry: Running boards (part DUEX)
Oh yeah, she's rough but that will make the progress pics even more sweeter to see. Let's see some pics.
Old 02-26-2006, 07:41 PM
CrashFarmer2's Avatar
Freezing in arctic Iowa
Last wiki edit: Pre-1980 VIN decoding
Last journal entry: 1978 Chevy pickup battery tray repair
Wiki Edits: 409
I like it. I see a lot of potential there.
Old 02-27-2006, 08:57 PM
Old Timer,
That's the way it's supposed to look. All our rides started out that way. Mine came in three pieces. Cab was on the old frame, The bed was tied on with old rotted rope, and the nose was in the bed. When my wife first saw it on the back of the tow truck being delivered, she said: "Oh, yeah...It's got potential."
55 Chevy Sedan Delivery or Nomad sbader7248 Hotrodders' Lounge 10 05-30-2005 02:57 AM
1932 Sedan Delivery Mfgs? McDeuce Body - Exterior 5 11-04-2004 06:17 AM
55 Chevy Sedan Delivery or Nomad sbader7248 Body - Exterior 2 07-01-2002 10:16 PM
55 Chevy Sedan Delivery or Nomad sbader7248 Hotrodders' Lounge 0 06-28-2002 06:09 PM
I need help with my 49 Dodge johnnyg23 Hotrodders' Lounge 3 01-31-2002 11:40 AM
