Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 49' F1 brakes on 39 Ford spindles
Old 02-08-2008, 07:20 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
There may be some differences between f1 and the later f100 brakes, the f100 brakes are a common swap.Check this article out,
http://www.flatheadv8.org/f1brakes1.htm
Courtesy of Deuce..
And a little more info by Pasadenahotrods regarding which spindle you may have and bolt patterns and such...
Early Ford Spindles fitting early Ford axles
I found those using the search function here on the site.
Hope this helps, mikey
BE different....ACT normal.
