49 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-02-2005, 12:25 PM
49 ford
hello ,my name is walt and i have a 49 ford, i have chopped the top, dropped in a 351 stroker motor and a c6 tranny. i am running out of $ and would like to swap the front drum brakes for discs. i am looking for any info on what doner car may be used to do this.i would also like to do power steering i was hoping i would find someone that had done this but so far it seems there isnt.there are many places that sell conversion kits but like i said money is running out.a doner car is needed i would greatly appreciate any info thank you walt.
Old 09-02-2005, 02:31 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders Walt. If you place your posts in the proper forums you might get more response to them.
Old 09-02-2005, 02:44 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Welcome. I'll move you to the proper forum for better response. Be sure to read the "New Member" posts at the top of the forums so you use the board to best advantage.
Old 09-02-2005, 06:03 PM
aka Duke of URL
Originally Posted by walt hennig
...would like to swap the front drum brakes for discs. i am looking for any info on what doner car may be used to do this. i would also like to do power steering i was hoping i would find someone that had done this but so far it seems there isnt. there are many places that sell conversion kits but like i said money is running out.a doner car is needed i would greatly appreciate any info thank you walt.
Without the use of readily available conversion kits (the 49 uses pins instead of ball joints) to mount disc and power steering, I would look at a partial MUST II kit. You can either use the OEM crossmember or just the crossmember from a conversion kit.
The rest (suspension and steering) can come from a salvage yard or donor vehicle. You can mount GRANADA 11" rotors. You will have a rack and pinion.
This is the only low cost alternative I see.
-ROD & CUSTOM MOTORSPORTS-
Old 11-05-2005, 08:47 AM
Model A's
Fatmans make a conversion kit for the shoe box fords for disc brakes. He also has the adapter to use a Volo power steering box with your ford pitman arm. These work great. chero
Wanna Talk Cars "Fords" 66Falcon Hotrodders' Lounge 17 10-01-2005 06:29 AM
'49 Ford Suspension CHUCK CRUSE Suspension - Brakes - Steering 2 07-17-2005 12:14 PM
49 Ford CHUCK CRUSE Introduce Yourself 1 07-13-2005 08:06 PM
anyone know of a disc brake swap for 49' ford? Shoebox49' Suspension - Brakes - Steering 5 03-05-2004 11:18 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
