49 ford custom rear end locked up - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2012, 01:51 PM
Okay, while moving the 49' without a drive shaft and yolk the carrier bushing popped out and kinked the ring and pinion setup. I jacked up the car trying to rotate the tires and hope I could pop it back in but that did not work. I then figured I would remove the carrier but I cannot get it off either. It comes out about 1/2" but no more past that. My father mentioned that some rear ends would require you to remove the axels to get the carrier off. I don't know if this is one of those or not.
We are not sure what to do next.
Help? Ideas? anything?
Thank you!
Old 01-23-2012, 04:52 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Thank you!
You have to take the axles out to remove the center section. You need to pull the axles and remove the center section "carrier" and see if you done any damage. Hopefully you can just bolt a yoke on and reinstall it but it's worth taking a look at.
Custom front and rear bumpers? I need some help. bio_research Hotrodding Basics 8 01-13-2012 10:56 PM
Hydro-locked Ford 3 liter jcclark Engine 7 06-20-2006 05:35 AM
Custom Ford 9" Rear Build: NLang Transmission - Rearend 6 12-19-2005 09:16 PM
Rear sway bar -custom? Rich_Long Suspension - Brakes - Steering 1 08-17-2004 12:45 PM
rear wheel locked on 77 vette john69 Transmission - Rearend 6 10-28-2002 12:23 PM
